Configures the IGMP snooping leave timeout.
leave_timeout_ms | Specifies an IGMP leave timeout value in milliseconds. |
vlan_name | Applies the configuration only to the specified VLAN. If no VLAN is specified, the configuration applies to all VLANs. |
1000 ms.
The leave-timeout is the IGMP leave override interval. If no other hosts override the IGMP leave by the end of this interval, the receiver port is removed.
The range is 0 - 175000 ms (175 seconds). For timeout values of one second or less, you must set the leave-timeout to a multiple– of 100 ms. For values of more than one second, you must set the leave-timeout to a multiple of 1000 ms (one second).
The following example configures the IGMP snooping leave timeout to one second:
configure igmp snooping leave-timeout 1000
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the IGMP snooping feature, see the Switch Engine v33.1.1 Licensing Guide document.
